where can I pull up a history file used by Endless Slideshow Screensaver?
I have a folder with thousands and thousands of pictures and I've seen a one I wanna see again - how can I pull up a history? :)
thank you
history
Re: history
By default Endless Slideshow Screensaver history file is located in the following folder:
C:\Users\YOUR-USERNAME\AppData\Local\Endless Slideshow Screensaver\history.dat
You can Google something like "decode URL online" to decode file names in that file.
Re: history
thank you
I found the file and converted it into HTML to see ALL the images :) to find the one I need
thank you
thank you
