Download from forum.thotsbay.com thread
steal107
Post by steal107 »
Been trying to download all the pictures on a specific forum page
https://forum.thotsbay.com/threads/anri ... post-46405
I have tried the thotsbay template do i have to change the settings or something else cause it doesnt download properly, is there a different way to set up the template. I usually just use the downloaded template and it works on the sites but I cant get any to work on specific pages on forums any help would be great thank you
Once this is fixed it will also help on other forums posts that I am trying to download, thanks for great product.
Re: Download from forum.thotsbay.com thread
I see that account is required in order to download from this forum. You can send the account info to support@exisoftware.com (change the password before sending, if you want).
Here is a template:
forum.thotsbay.com thread downloader
Works with thotsbay.com forum threads. Download albums from external image and video hosts like cyberdrop.me, erome.com and others.
Boboson
Post by Boboson »
Hi I am having a similar issue. I am unable to download the images from thotsbay forums. When I use the template it only downloads one image.
The software is only downloading the thumbnails of the images. Note: The images are from the forum itself rather than an alternative hosting site like cyberdrop.
Template was updated to enable "attachment" downloads. Please re-download the template and create new project.
Yet another template update to fix bunkr.is downloads (they changed the way they supply video files) and add direct videos from
forum.thotsbay.com/data/video/
Be sure to have the most recent version of the template:
forum.thotsbay.com - thread downloader
Also, if some images, videos or albums linked from forum threads are not downloaded - please reply to this thread to let me know - I'll try to fix it.
For example, albums from GoFile.io cannot be batch-downloaded with this template - you have to use a separate template for those albums:
gofile.io downloader
And you have to create one project for one album only.
