hi
i see you have the templates for ashemaletube however they dont seem to work correctly to rip all the galleries from a catagory or search term.eg
https://www.ashemaletube.com/pics/gifs/ ... lar/today/
is there any way this can be done?
much thanks in advance.
hi, a new template for ashemaletube.com
Re: hi, a new template for ashemaletube.com
I did not see any problems with the template. I tried your URL, then another category and the search results - everything worked as it should. What is in the download log of your project?
it just runs almost indefinitely but never downloads any gifs which are the targeted files.
Please re-download the template and re-create the project.
ashemaletube.com - download shemale pictures
still no luck, no gifs downloaded, how do i share a job log?
Send it to support@exisoftware.com as an attachment
