How to scrape xVideos.red (Premium xVideos)?
ibraap
Re: How to scrape xVideos.red (Premium xVideos)?
Post by ibraap »
Videos are saving but only at 640 x 360 resolution.
Anyway to obtain larger versions?
OK, I found a way to do it. Please download the updated template and re-create your project(s):
xvideos.red channel videos downloader
ibraap
Post by ibraap »
Works great, thank you!
deadbeatdandylyon
Post by deadbeatdandylyon »
Hello, I recently came across this page, I am receiving the same error as the previous person did, i did log into xvideos but don't have a premium x video account not sure if that would matter.
but the step by step process i took as
I first downloaded this xvideos.red channel videos downloader
Then I downloaded and installed - https://www.webimagedownloader.com/how- ... templates/
then followed the on screen prompts logged in when it told me to log in and then click on continue download but keep getting the below message, is this no longer active?
Template you downloaded from the online template database failed and we are sorry about it. First of all, please make sure you have the most recent version of the template and minimum required version of the program - click [ Open template page ] button. If you have all required versions, then in most cases download fails because the website was changed since the template was created and now the template needs to be updated to reflect those changes. Please click [ Report broken template ] button and let us know about this problem. You can also take a look at your Starting URL in the built-in browser to spot any problems by enabling [ Manual login ] in the project properties
Do you have access to the videos you are trying to donwload in your browser? Can you view those videos in your browser with your non-premium account?
neonhomer
Post by neonhomer »
It looks like xvideos.red changed their format again or something.
https://www.xvideos.red/hana_lily_official
or
https://www.xvideos.red/hana_lily_official#_tabRed
When I put this into EPF, it won't auto select a template. I manually select the Xvideos.red template, and once I sign in, it will give me the error that it can't find anything. I did submit a broken template report through the app....
OK, the new version along with the new template is supposed to work fine with the new channels format:
Download Extreme Picture Finder
But be careful, xvideos.red may disable your account if download too fast, so do remove the delay between downloads and do not increase the number of simultaneous connections.
