Ok, so to me, this should have been something I could have solved on my own, but after countless hours of trial and error, I've come to the forums in hopes that someone is generous enough to take a moment to help me see what I'm missing..
I figured starting with the existing xVideos Template(s) would be my best bet, but no matter the changes I've made to the template settings, I am still unable to scrape/download any of the content.
Account cookies are saved, so that's not the problem but it must be due to the domain name settings or something similar that I'm not understanding .
Anyway, I'd greatly appreciate it if someone could point me in the right direction, that would allow me to scrape videos from a channel link, such as
Link Example: https://www.xvideos.red/channels/bangbros-18#_tabRed
Similar Template: https://www.webimagedownloader.com/temp ... -template/
Heck, I'd be willing to even share website credentials with any member that would either require access to create this template, or even if they'd like to scrape a bit from it, as my way of saying "Thank you".
Let me know what I'm missing :)
How to scrape xVideos.red (Premium xVideos)?
Re: How to scrape xVideos.red (Premium xVideos)?
If you want me to try to help you with this template - send account info to support@exisoftware.com (change your password before sending).
No problem at all.Maxim wrote: 15 Feb 2022, 11:38 If you want me to try to help you with this template - send account info to support@exisoftware.com (change your password before sending).
Please help me understand how to PM you through this forum though or supply me with some other type of contact info so I can send credentials.
Thank you for your assistance.
Just as I said before - email it to support@exisoftware.com
...That's just embarrasing that I didn't spot that the first time. My appologies.
Email was sent just now.
Feel free to close/delete this thread if I am unable to, myself.
Thank you again.
OK, here is a template:
xvideos.red channel videos downloader
Please try it and let me know if it worked for you.
No, this did template did not work for a few of the categories I have just tried.
Example link: https://www.xvideos.red/channels/bangbros-18#_tabRed
It would be important to only scrape videos from the 'red' tab as those are what we're paying the subscription for.
Thank you ,again.
Edit:
Might help to add the following error that is shown after.
(log)
Thank you ,again.
Edit:
(log)
The log looks like you did not sing in in the built-in browser. Did you?
Yes, my account was logged in through the browser.
Are you able to produce different results? If so, I must have done something wrong and I will revisit shortly.
Edit:
It would seem as though I wasn't logged in, since I am having no trouble using the template you created yesterday.
Thank you again.
Edit:
Thank you again.
So, everything is fine now? You're getting the videos?
