Any chance to get malibustrings.com template? Preferrably for a full-year rips.
Also for microminimus.com/bikini_contest. Same full-year rips.
Thanks in advance.
Malibustrings, microminimus template
Re: Malibustrings, microminimus template
Have you tried generic template called "Download all images from website" with Malibustrings? Works perfectly. Generic templates as well as default project settings is the first thing you should try with any website.
Thanks for getting back.
Yeah, I've tried "Download all images from website" with Malibustrings. It does work fine. I just can't reproduce folder structure/naming.
Can you also provide some help with microminimus.com/bikini_contest? Can't seem to make it work at all.
Regards
Regards
This website requires a paid account, does it?
No, /bikini_contest part is free
OK, here is a project for the bikini contest:
microminimus.com - bikini contest
I didn't find a way to save the pics by year. Only by gallery. You can try creating separate projects for different years with starting URLs like this:
https://microminimus.com/api/bikini-con ... ?year=2007
https://microminimus.com/api/bikini-con ... ?year=2008
https://microminimus.com/api/bikini-con ... ?year=2021
But I'm not sure it'll work as intended.
