Video Problem
Bigjosher
Video Problem
Post by Bigjosher »
I am trying to crawl a website that has .mp4 files on it, but yet when I go to set the engine up in the drop-down list, I chose video file where .mp4 is one of them. The engine does not pick up the files of mp4 format, it picks up the jpeg files that is the video thumbnail nut not the video itself. why is there a video file option when it wont download them at all when it is selected, or am I doing something wrong? don't I just select the video from the drop-down?
Re: Video Problem
What website are you trying to download from?
Bigjosher
Re: Video Problem
Post by Bigjosher »
A list of certain site channels, on goodporn.to
Re: Video Problem
I'll try to create a template for this website.
Basically, all you have to do is adding
\.mp4
to the "Included URLs".
Bigjosher
Re: Video Problem
Post by Bigjosher »
Really, thats all i had to do <.<, it's working now. thank you. Why did this work in "included urls"? I thought I just need to choose it in drop down?. again thank you
Re: Video Problem
Well, if you take a look at the video page source, you'll see that video links look like this:
goodporn.to/get_file/blah-blah/29049_1080p.mp4/?download=true&download_filename=file-name
And this little "/" after ".mp4" makes the URL look like a folder URL, not like a direct file URL :( If the URL looked like this:
goodporn.to/get_file/blah-blah/29049_1080p.mp4?download=true&download_filename=file-name
then Extreme Picture Finder would have picked it up automatically as a Target File URL.
Another way of fixing this problem would be changing the Exploration limits in your project. It looks like you limited Extreme Picture Finder in a way that it ignores the video URLs. Maybe you set the "Exploration limit" to "Current directory and deeper" or to "Current page only" and the video URL lies outside the exploration limit (again, only because URL is not pointing to a target file, but to a "folder").
Re: Video Problem
And here is a template, as I promised:
goodporn.to video downloader
