fetlife template stopped working
jamieg1
Post by jamieg1 » 23 Oct 2021, 03:10
I've been using the fetlife template for months without problem Last night it stopped working. Is there a fix?
Re: fetlife template stopped working
Post by Maxim » 23 Oct 2021, 13:05
Please download and install the updated template:
fetlife.com - member pictures and videos template
It is now working separately for pictures and videos. So if you want both pics and vids - add 2 corresponding Starting URLs to your project.
jamieg1
Post by jamieg1 » 23 Oct 2021, 17:15
Thank you for your prompt attention to this!
Robs
Post by Robs » 24 Oct 2021, 08:31
this was working til I updated the the template and now it has stoped working is there a fix?
Post by Maxim » 24 Oct 2021, 14:13
Please try to re-login in Extreme Picture Finder's built-in browser. Click the [ Delete cookies and reload page ] button, then enter your login/password, then click [ Continue download ] button.
Robs
Post by Robs » 24 Oct 2021, 23:52
Hi yes i have tried this it will log back on to the page then I click continue download and fails with the same resolute it try's to connect and then give the error
Post by Maxim » 25 Oct 2021, 11:30
Well, in this case it's not a template problem. It's the connection problem. Maybe you set a proxy in Extreme Picture Finder? What's in the project's download log?
Robs
Post by Robs » 25 Oct 2021, 12:41
Hi no proxy is set, This was working before i updated the template. the error i get is
Your project finished but zero target files were saved. First of all - check your strarting URL in your browser to see if it is correct. Then make sure you specified correct tagrget files (if you wanted video files and your Target files are *.jpg - Extreme Picture Finder won't save anything). It's also a good idea to see the download log (click the [ View project download log ] button) to find out what addresses were crawled by Extreme Picture Finder and with what result.
this is all i have in the log
https://fetlife.com/users/11738345/pictures depth 0, http response 200-ok
When I add jpg to the list it will down load 30 files then stops
Post by Maxim » 25 Oct 2021, 13:14
Hmm. Interesting. It's possible that for different accounts different HTML page text is generated. Can you give me your fetlife.com login/password for the tests? Change the password before sending it to support@exisoftware.com if you want to.
Robs
Post by Robs » 25 Oct 2021, 13:33
sent the logon detail to support
