Nested gallery folders
I am new to this software and it seems to have a lot of potential. What appears to be missing is multi-folder galleries going down one or more levels. It would be wonderful if this could be made an option. Thanks.
Re: Nested gallery folders
Currently it's impossible in the program. Adding to the to-do list. Thank you for the suggestion.
Thank you. Multi-level gallery folders would really expand the capabilities of this software. To date I have used the Arles image gallery software, but they no longer update the software and am now finding it limited especially when it comes to responsive websites.
Sounds like a nice feature...
Movie support
With other software you can create galleries with movies. The generated movie thumbnails can link either directly to the movie file or a webpage with an embedded movie. The built-in Select Movie Frame tool allows you to specify what frame you want Arles to use to generate the thumbnail.
Movie support
