Image problem
Image problem
can someone please tell me what I am doing wrong. I am trying to download a website that has web image(.WEBP) images on it, when I set up EPF to scan the site and I even check the .WEBP file type, I run the scan and it does not even pick one out
Re: Image problem
What website are you trying to scan?
Re: Image problem
just all the pictures from https://avn.com/porn-stars/female to be honest i need for a project
Re: Image problem
I do not see any WEBP images there. All links are leading to
https://stars.avn.com/NAME
where you need to pay to get access to the photos.
What am I missing?
What am I missing?
Re: Image problem
https://avn.com/porn-stars maybe that did I paste the wrong site, I got into this free
Re: Image problem
So, you just need portrait images from this single page?
Re: Image problem
thats is correct, since it is auto loading, just one page
Re: Image problem
Here is a project for you:
avn.com-porn-stars
Right-click the above link and select [ Save link as... ] in the pop-up menu. Then double-click the saved file to add the project to Extreme Picture Finder. Then start the project in the program.
avn.com-porn-stars
