Hi, can you help with vk.com template to download all user albums with album names:
https://vk.com/albums-199597680
VK template
Re: VK template
Does the template download files? Is it just the album names that you want fixed?
Re: VK template
Current vk.com has only album template and it does download files, but it has a bug - every photo in the album downloads 4 times in different sizes.
So I need help with the template to download all albums from the same user, preferably so that every album has it's own original, non-numerical name.
Re: VK template
Do you, by any chance, know a proxy server I could use to access vk.com? I cannot access it directly - the website is blocked in my country.
Re: VK template
There is a program called Psiphon. Both for Win and Android. Seems quite good and reliable
Re: VK template
Thanks. Looks like the program works. I'll let you know if I'll be able to fix the template.
Re: VK template
Also is it possible to request to add some project management features:
1) search project bar (by project name, links)
2) sort projects by order - old/new (important!) and by largest/smallest amount of downloads
This is gonna be super useful
Thank you
Thank you
Re: VK template
Thank you for the suggestions. Adding them to the to-do list.
Re: VK template
OK, I updated the template and the program to actually work properly with vk.com:
vk.com - download photo album template
So, first of all, you'll need the most recent version of the program:
Most important improvement - only best-resolution images are saved now and album titles are used for folder names instead of album IDs.
But I couldn't make the program go through all album addresses automatically, so the template page has a little tutorial showing how to use Extreme Picture Finder's built-in browser to export all album addresses from user "Photo albums" page.
Please try it and let me know it if works for you.
Re: VK template
I'm not the OP, but I tried your template, and it works perfectly, thanks!
By the way, the tutorial is clear and understandable, I'm usually pretty bad with new apps and programs, and even I could browse albums and download their content as I wanted.
