The website has a main page->topic->sub folder->xxxxxxxx.
The site also has affiliate links.
I just want to download the stuff in the 'xxxxxxx' folder. NOT the things from the affected links, how do I go about this?
Website with subfolders, newbie
Re: Website with subfolders, newbie
If you want me to try to help you with the settings - provide actual links and information on what you want to download. You can send everything to support@exisoftware.com or just post here.
actually its boobpedia i want to download the highest quality pics in the links but all i get is 800 and it scans 32000 links. how do i do this ive tried all settings
What about the actual URLs?
Https://www.boobpedia.com/ and al sub links inside the main page, not the ones one the sides or the bottom
https://www.boobpedia.com/wiki/images/f ... Lamarr.jpg
This is one example of a picture, its 4 links below main page
https://www.boobpedia.com/boobs/Category:Birth_year
Really all the sublinks in here is what im trying to pull
Try this project:
boobpedia.com - Category: Birth_year
Right-click on the above link, choose [ Save link as... ] from the pop-up menu then double-click the saved file to add the project to the program.
I couldn't go really deep into this because website is really slow and I could only open a page once in 10 attempts. But you can take a look at the project properties to see the way I excluded all unwanted links.
Ill try it and see what i can learn, is there any videos i can learn about this and code, the way it works. I thought i could just adjust in settings. I should have learned more about code in school.
Thank you:)
Thank you:)
