Help to create a template
nikks00
Post by nikks00 »
Hi, I'm having a problem to create a template for this specific manga website, I'm trying download every chapter in a separated folder but for some reason that i don't know it starts well but suddenly it jumps a lot of chapters that are in the same page or don't download all chapters. Here's a page example (it's in Portuguese):
https://www.supermangas.site/manga/bleach
Re: Help to create a template
Here is a template for any manga on this website:
supermangas.site - manga template
Please note that you need Extreme Picture Finder version 3.53.2 or newer for this template to work. So if you have older version - please update:
nikks00
Post by nikks00 »
Unfortunately this template has the same problem as mine still skips several chapters and does not download them all.
This manga in specific has more than 300 chapters, EPF only download until 50 and skip some chapters.
Are you sure you used the correct template? Maybe you created a project and the template that was automatically chosen was yours? Please delete your template in the template library (menu item [ Templates - Open local templates library... ]), then create a new project using the template from the website and try again.
nikks00
Post by nikks00 »
I only have you template for that website, here:
The strange thing was that I created a new project with the same template and it downloaded different folders than the first time, still skipping chapters.
Does the project finish without completely downloading all the chapters or you just stop it? You see, it will never download chapter one by one in order they are presented on the website. It'll download chapters in random order, but it will download them all eventually.
nikks00
Post by nikks00 »
It finishes without download all.
OK, I see. Please re-download the template. I added the delay between download and now it seems to be working better. Please do not use more than 5 simultaneous connections and do not remove delay between downloads.
nikks00
Post by nikks00 »
Looks like that was the problem now it's working thanks.
