turn off safe search
smith
Post by smith »
Hi Maxim
can you help me to turn off the safe search in search mode
any registry tweak is also ok
thank you
Re: turn off safe search
Which version of the program do you have?
smith
Post by smith »
version 3.50.00
There are 2 search engines in this version where you can turn off safe search. You can see that the rest of them have safe search "Always on" because they require people to login to turn it off.
Heinz
Post by Heinz »
I have version 3.42.7 - where do I turn of SafeSearch?
You need to get version 3.50 to get adult results from the built-in picture search:
Safe search is turned off by default for all search engines that support it. Currently it's Google and DuckDuckGo.
Heinz
Post by Heinz »
Ok I have now downloaded and installed version 3.50, STILL SafeSearch restricted.
My browsers have SafeSearch switched off.
I ran this as a REG
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\SearchSettings]
"SafeSearchMode"=dword:00000000
Still does NOT help.
You do not get unsafe search results in Google and DuckDuckGo?
Heinz
Post by Heinz »
No problem in Google or DuckDuckGo
Images show properly in both
Well, as I said earlier, Extreme Picture Finder simply cannot extract unsafe images from other search engines right now.
