template for artstation.com
freeman
Post by freeman »
please create the template for the following link
https://www.artstation.com/kyuyongeom
Thank you very much.
Re: template for artstation.com
Here is a template:
artstation.com portfolio downloader
Please try it and let me know if it worked for you.
freeman
Post by freeman »
The template is working. Thank you.
P1L0
Post by P1L0 »
Hi!
I would like to know how to make a deeper downloading of a portfolio. Mostly of the portfolios have several images under their thumbnails and this templates only downloads the first image of the stack.
How can I fix that?
Thanks in advance!
Can you give me an example URL?
P1L0
Post by P1L0 »
Yes. For instance, https://www.artstation.com/shitong.
You got multiple images under the most of the thumbnails but EPF downloads 1 on each.
Please try the updated template and let me know if it worked for you:
You will need Extreme Picture Finder 3.63 or newer for it to work.
P1L0
Post by P1L0 »
Thank you very much. It works!
Now it's time to practice
You are welcome!
