Where is the config file?
Magicmaniac
Post by Magicmaniac »
I am going to be moving my Slideshow software to my new digital photoframe computer. I have made dozens of change to the config file and I was hoping I could just copy the config file over to my new machine. I can't seem to find a config file in Program data or Program file directories.
Is there a way to do this? I understand I'll have to go in and change the path names etc but it would save a lot of time.
Kevin
Re: Where is the config file?
Endless Slideshow Screensaver stores all the settings in Windows Registry. Simply export the following key:
HKEY_CURRENT_USER\Software\Extreme Internet Software\Endless Slideshow Screensaver
and then import it on your new computer. You can access Windows Registry by pressing [ Win + R ] on your keyboard and then enter the following command:
regedit
Magicmaniac
Thanks!
