Take for example the http://vintage-erotica-forum.com/showpo ... stcount=66
(by the way, thanks for updating the template)
number of simultaneous connections 30 = 62 files
number of simultaneous connections 1 = 75 files
save manually from browser = 76 files
Is this inevitable or am I misconfiguring?
Lost downloads (number of simultaneous connections)
Re: Lost downloads (number of simultaneous connections)
Hmm. I'd like to investigate. Send me a valid user name / password for this website please to support@exisoftware.com.
OK, here are the results of the investigation. First of all, and most important - it's not a program bug. This is the way imagevanue.com works. When the image page is first loaded - it does not contain the actual image. It sets a cookie and then redirects to the page with the actual full-size image. And when you're doing it one-by-one (1 simultaneous connection) - it works just fine. But when 30 pages are trying to set a cookie at the same time - the result is complete mess :(
So I suggest using 1 simultaneous connection for threads or posts that host images on imagevanue.com.
