EPF - Manual Login - Bad browser -Unable to login vk.com
nnina084
Post by nnina084 »
EPF - Manual Login - badbrowser Unable to login
Internet Explorer 11 (Windows 7) NOT SUPPORT!
Your browser is out of date
This may cause VK to work slowly or experience errors. For speed and stability, we recommend you install the latest version of one of the following browsers:
Internet: Connection > User Agent > Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:72.0) Gecko/20100101 Firefox/72.0
still can't log in, because VK sees EPF as IE
Re: EPF - Manual Login - Bad browser -Unable to login vk.com
Extreme Picture Finder uses Internet Explorer as a built-in browser. There is no other browser which allows such integration.
Sander
Post by Sander »
Maksym wrote: 16 Feb 2020, 11:45 Extreme Picture Finder uses these fantastic rangefinder binoculars and Internet Explorer as a built-in browser. There is no other browser which allows such integration.
Not even Microsoft Edge?
Unfortunately :( If MS Edge was available like IE it would have solved all the problems.
