I posted this in the other imagefap thread the other day but I think it might have been overlooked. If not sorry for doubling up and delete if you see fit.
When I try and download a user's folder (imagefap.com - all galleries from a folder in user profile), EPF will download the first gallery and then stop. If I restart or update, it will redownload the first gallery duplicating pics and stop. It won't proceed to the next/other galleries.
If there's more than 1 page in the folder, EPF will download the 1st folder per page and then stop.
I'm using EPF 3.46 and updated IF templates (imagefap.com - all galleries from a folder in user profile version 14)
Thanks for the naming fix.
"imagefap.com - all galleries from a folder in user profile" only downloads 1st gallery
Re: "imagefap.com - all galleries from a folder in user profile" only downloads 1st gallery
I'm sorry, I didn't see in the other thread, but it's there for sure.
Turned out there was a bug in the Excluded Page Parts and all galleries were simply cut out :( Now the problem is fixed and the template was updated. So please download and install new version of the program:
Download Extreme Picture Finder
Along with the updated template:
Cheers thanks. Looks good.
