How to Delete Projects and Files
zFilez
Post by zFilez »
Projects and Files cannot be deleted. Can someone reply with Instructions?
Re: How to Delete Projects and Files
Yes, it happens sometimes. There are 2 ways to do it in this case:
1. Run Extreme Picture Finder as Administrator
2. Delete manually from Windows Explorer. You can easily open the project folder using a small folder button at the end of the folder name:
And opening a project file location in Windows Explorer also takes a few clicks. Open project properties, select [ Project file ] section and click [ Open project file folder... ] button:
zFilez
Post by zFilez »
Thank you
