Hi @ all,
i have problems to download more than one gallery from ftvgirls.com, i think that the site use
Captcha by use the extreme oicture finder, than i get some Captcha by downloadings tests
i use the template but i didnt works :(,
ervery one idea, how i can login manualy if comes a Captcha ??
thanks for help
ftvgirls.com Problem by loading pic
Re: ftvgirls.com Problem by loading pic
I updated the template. I added a delay between downloads along with maximum number of connections limit. Please try it and let me know if it helped.
members.ftvgirls.com - model template
Hi Maxim,
it still not works fine :(
first picture i get the "Cptcha" pic and pic´s from the root of the site
After some sites goes the program outsite of ftvgirls.com, (youtube.com usw..)
any ideas
any ideas
I'll need login/password for this website if you want me to dig deeper. You can send them to support@exisoftware.com.
You have Mail
