TheFoxxx.com
AstrYx1
TheFoxxx.com
Post by AstrYx1 » 29 Sep 2019, 11:13
Can I have a template for this site with auto naming for each string? because when I download the files the folders end up like this:
...The foxxx\2019\08\19\episode-32-naked-yoga-lessons-i
instead of creating only 1 folder with it's name.
...The foxxx\episode-32-naked-yoga-lessons-i
here's a link:
http://thefoxxx.com/blog/2015/02/09/ali ... n-batbabe/
Thanks for your time.
Re: TheFoxxx.com
Post by Maxim » 29 Sep 2019, 13:04
You'll need to use "Expert" tab in the [ Save -> Sub-folders ] section of the project properties. Select the "Use target file parent URL Regular Expression" option and add the following Regular Expression:
Expression: .*/([^/]+)/$
Result: [#1]
Also adding
\d+x\d+\.
to the "Excluded URLs" filter will prevent the download of thumbnails.
AstrYx1
Re: TheFoxxx.com
Post by AstrYx1 » 29 Sep 2019, 20:40
It worked thanks.
