Manual Login password not working
mattsmizzy
Post by mattsmizzy »
Been awhile since using the program. Updated to 3.44 after having problems. And still have same problem after updating
Trying to use manual login for passworded sites.
Multiple sites that i have used in the past but when the browser window pops open that i would enter user/pass im getting this.
This program cannot display the webpage
Most likely causes:
•You are not connected to the Internet.
•The website is encountering problems.
•There might be a typing error in the address.
I dont have internet explorer installed. Never have and its worked before. running win 7. But looks like its opening up a Palemoon browser tab. Which it always has. But for some reason has stopped working. but If i open up palemoon browser itself i can browse internet just fine.
Im definitely connected. Havent changed anything since last time it worked which i cant remember when that was. probably 5-6 plus months ago.
i have Cleared cache in internet options in control panel of win 7 think maybe that would help but didnt.
Cant really think of anything else to try. Maybe switch what browser it uses instead of palemoon like opera or firefox or chrome. But dont think i have ever seen that option in the settings anywhere.
thanks for any help
Re: Manual Login password not working
Internet Explorer is used in Extreme Picture Finder as a built-in browser. So you must have it installed and updated to the most recent version in order to make it all work.
