Has anyone worked with thechive.com sites? Trying to get the proper settings or template so I can get the images from a link like https://i.thechive.com/halfassmonkeyboy
Appreciate any hints or help!
Thank you
Need assistance for https://i.thechive.com
Re: Need assistance for https://i.thechive.com
Here is a template which can help you download all submissions from any user on i.thechive.com:
i.thechive.com - user submissions template
You're a god.. thank you!
One more request, if you have the time:
A template to handle tag searches on i.thechive.com. Example:
https://i.thechive.com/tag/sunset
Thank you in advance
Hmm. Doesn't look like it can be done. I can only get the first page of results, which is
https://i.thechive.com/rest/uploads?see ... tag=sunset
It can be generated using Custom Parsers from the page text of the original starting URL:
But after that I need both "seed" and "tag" values and I do not see a way to generate such URL from the first page of results because it lists all tags for every submission and does not indicate which one was used to generate this page :( I would need to use both page URL and page text to generate the next URL and that's currently not possible. Custom Parsers work ONLY with the page text, they cannot use the page URL. This feature definitely must be added...
No worries.. thanks for taking a look anyway
