Download only from certain links
crunchie
Post by crunchie »
Hello I only want to download the images from drama and movie category of this website.
How can I remove the actor and author images from the downloads
www.chinesedrama.info
Thank you ^^
Re: Download only from certain links
In general, if you want to download from a limited amount of links on a website - you add that entire website to the "Excluded URLs" like this:
chinesedrama\.info
And then add filters to the "Included URLs" that will cover all the pages you want.
In your case, if you want only drama and movies, I would use the following Starting URLs:
http://www.chinesedrama.info/p/movie-list.html
http://www.chinesedrama.info/p/drama-list.html
Since they have links to all pages you need. Leave the Exploration type as it is - Regular Site -> Entire site. Use the following Expressions in the "Included URLs":
chinesedrama\.info/\d+/\d+/(web-)?drama-[^/]+\.html$
chinesedrama\.info/\d+/\d+/movie-[^/]+\.html$
Basically that's it. You can also configure Extreme Picture Finder to save pictures from different movies and drama into separate folders using "Expert" mode in the "Sub-folders" section. Just like I did in this project:
chinesedrama.info - movie and drama
Right-click the above link, click "Save link as..." and then run the downloaded file.
crunchie
Post by crunchie »
Thank you for the help ^^. I am really confused about the regular expressions. I'll try to learn them on my own. Btw, I downloaded the images but some images are not downloaded as the site has toggle function to display more images. How can I download the images from the toggle function
Here is an example link:
http://www.chinesedrama.info/2019/01/dr ... ulder.html
they belong to these containers
<div id = "posterheader">
<div id = "stillheader">
Thank you!
I think you need to add the following filter to the "Included URLs":
s=\d+\?
crunchie
Post by crunchie »
Hi I included the filter to the included urls but the files downloaded from the filter does not save in the same name folder. Thank you!
Please correct that filter with a more generic one:
googleusercontent\.com/
Also everything is saved into correct sub-folder for me. So I'll need an address of the page where images are not saved into sub-folders.
crunchie
Post by crunchie »
Hello I noticed that the web drama pages does not create its own sub folder. I'm sorry for disturbing you. Thank you!
http://www.chinesedrama.info/2018/08/we ... -love.html
This is the result I'm getting:
