I would love an option to not download duplicates (could be done via md5), at least in a given project download session.
Barring that perhaps an option added to After Completion to run an external program (that could remove duplicates).
Barring that :) perhaps a way to select images to be donwloaded vs. downloading all images.
Prevent Duplicates
Re: Prevent Duplicates
Have you seen the [ Conflicts ] section in the project properties? There are some options here that may actually help you prevent downloading and/or saving the duplicates.
Thank you that (Do not download..) will work just fine, surprised I overlooked that one (now gotta double check it's in my version :) haha). I appreciate the support, will be making a purchase soon.
Make sure you have the most recent version of the program. You can always download it here:
http://www.webimagedownloader.com/download/
