suicidegirls - FULL
Thewtfguy142
suicidegirls - FULL
Post by Thewtfguy142 »
I have made 3 thread, so sorry for the others. I changed and changed and I think I got it fully now, so if a moderator sees this please remove the other 2.
I am using Suicidegirls website and I wanna download some photosets and devide them in folders.
So if there is a profile I go in and she has 3 photo set I would like to just be able to download those 3 album set but then divide them into 3 folder that the photo sets are called...
If someone I great at this I can give login for it and get a template working for that :)
Re: suicidegirls - FULL
Thewtfguy142
I tried that template and it's not working the way I want it to. For me I want the photoset to be devided into folders with that user.
Let's use an example. This profile named : Amanda
She has two photo set and it's named "Black Cat Eyes" and "First Fly" I reccon there is around 50 - 100 images togheter with both sets and when using the template you linked it only downloaded 7. Yes, I am a member and logged in manualy.
What I would a template to do is to download all images and make two folder that was named after hers photoset and download all photo's.
If you can do that it would be great, I am also able to give you the login so that you can try and test to make it work.
OK, send me your login information to support@exisoftware.com
OK, got it. The template was fixed to work properly with both free and members-only photos:
suicidegirls.com - all photos of any model template
Please re-download, try it and let me know the result.
Thewtfguy142
Maxim wrote: 28 Nov 2017, 13:17 OK, got it. The template was fixed to work properly with both free and members-only photos:
Yeah it worked as I wanted :3 Awesome :) Does this work with multiple lines in project settings? Like if I paste in more than 1 model? Or just one?
EDIT: Not working completly 100% Took a test and there was one with 9 sets and it only downloaded 6 folder. Don't know why? Link to the one I tested with the template you linked.
https://www.suicidegirls.com/girls/miss ... ez/photos/
Turns out this is because other albums are from different girls. So, most of the albums listed there are from "missfernandez" but there are also albums from "rogue":
https://www.suicidegirls.com/girls/roug ... 1/jinkies/
and from "ondinae":
https://www.suicidegirls.com/girls/ondi ... 5/chimera/
That's why they were not downloaded.
Thewtfguy142
Maxim wrote: 29 Nov 2017, 14:53 Turns out this is because other albums are from different girls. So, most of the albums listed there are from "missfernandez" but there are also albums from "rogue":
and from "ondinae":
Ohh damn, alright that was sorted :P Thanks man :D'
EDIT: A question you maybe can answer. You typed that it was from another album / artist .. If you head over to https://www.suicidegirls.com/members/vi ... sh/photos/ you can see that she only got 1 set and the other is owned by another one. Dunno why the website has it like this. But if you download that link with the template it download boths of them? It should only download the one?
Second Edit: Does this template work with several links? :D Or well maybe not? Cause It seems to download all files I do the manual login and then go to the bottom and click "load more" dunno if that could be fixed?
If you take a closer look - they are both from the same girl "victoriadash":
https://www.suicidegirls.com/members/victoriadash/album/3265902/naked-nintendo/
https://www.suicidegirls.com/members/victoriadash/album/3019436/team-mystic-for-the-win/
And they are both downloaded just fine with the current template and Manual login
Nope, sorry. Most templates that require Manual login, including this one, work with one link at a time.
Thewtfguy142
Same thing here.. This user
https://www.suicidegirls.com/members/stephyrodriguez/
I wanna download their album I TAWT I TAW A PUDDYTAT!
I use this link : https://www.suicidegirls.com/members/st ... ez/photos/
But will download a other album? I tried to go to that Fishball and download all albums there too but nothing. How the fack can I get it otherwise? There is no other user right?
Edit: I removed many of my projects and it worked. Like wtf? I tried made like 5 project the same never worked. Removed my project that I had from before and worked? Any connection on that?
