Files not copied when New Gallery is created ver 2.0.2.0
Not sure if it's just me, but when I create a new gallery, populate it and generate it, it seems the slideshow.js file (where used) and the two folders and file in the "files" folder are not copied to the destination. I have to do this manually. Does this sound like an install issue? I have my "Program Files" folder on my D: drive but the "ProgramData" folder is on the C: drive.
Re: Files not copied when New Gallery is created ver 2.0.2.0
Which template are you using?
It has happened with several templates. I have had to go into C:\ProgramData\Extreme Thumbnail Generator\Templates and copy the "files" folder content to my server. Classic is one. I'll have to look for the others that have given me this issue as well.
