show download log history?
shave1
Post by shave1 »
The monitor panel shows the current activity. By watching it, I can somewhat guess what the app is trying to do.
Can you log the activity history to be viewed to debug a project? Ideally with more detail of the decision the app is making, but just start with logging the activity in the monitor panel is good.
Re: show download log history?
Have you tried the [Project -> View download log...] menu item?
nero
Post by nero »
Is it possible to save the download log?
in menu item [Project -> View download log...] you can see the log, save single lines and so on. But saveing the complete log (from a project) i haven´t found, it is possible to do this? :)
i need the log to analyse, sort and optimize.
You can do it using menu item [ Project -> Export file list... ]. Simply select "All downloaded files and pages" in the [ What to export ] section at the top of the window.
nero
Post by nero »
wow so easy but i haven´t find it... i searched the "log-area" at the tool but there were nothing.
now i have found it and i think it worked. i will try it mehr the next days.
thank you
