Recently I updated the s/w because I was frequently needing to use CTRL-ALT-DEL to stop it. Since I updated, it still is required although less frequently. But some features seem no longer available:
1. Using arrow keys to advance or back up the photo shown
2. Showing the filename of the displayed photo
3. Using the delete key to remove a photo from its directory
Any suggestions?
Features missing after upgrade
Re: Features missing after upgrade
First of all - make sure you have upgraded to Pro version. Check screensaver settings, About tab. Then open Viewer -> Actions tab and see if all required actions are checked:
