Dude for website
n0rton
Dude for website
Post by n0rton »
It posible down to https://www.walldevil.com ?
or
www.pexels.com
flickr
Re: Dude for website
Flickr is used as one of the built-in search engines, so you can download flickr.com search results. But I couldn't figure out how to download flickr sets ater they changed API.
As for walldevil - I'll create a template which can download all wallpapers from any category and post a link here. Easy one.
Pexels is tough. Will take time, if doable at all...
n0rton
Post by n0rton »
Flickr include no?
walldevil maybe it ok, i see wallappers good.
OK, here goes the template for any wallpaper category on walldevil.com website:
You may also want to check out other wallpaper templates:
http://www.webimagedownloader.com/templ ... allpapers/
pexels.com easily working with the default built-in template called "Download all images from website". You should always try that template first for any website.
n0rton
Post by n0rton »
Pexels work fine. (can change for not down that tree?)
http://imgur.com/1lixvVZ
i see in alexa other website:
https://themetix.com/site/wallup.net/
similar traffic with walldevil, same script?
Use "Filters -> Excluded URLs" to prevent unwanted downloads. Just like I did in the wallup.com project here:
wallup.com.epr
I took the built-in template "Download all images from entire website" and then added some additional filters to the "Excluded UTLs" as I watched the download log while EPF was working...
You see, EPF can download from most websites using one of the built-in templates... You need more filters only to speed up the process...
n0rton
Post by n0rton »
Great Work.
I try to down normal website all images.
Code: Select all
https://www.pexels.com/search/lakes/
https://pixabay.com/en/photos/?image_type=photo&cat=nature
But down all folders not only images. Can help me?
In this case I prefer to exclude all URLs using
in the [ Filters -> Excluded URLs ] and then include only the ones I need in the [ Filters -> Included URLs ].
Here is the template I created for pexels.com search:
Download the template and use the URL just like the one you provided - the resulting URL of website search.
Here is a sample project I created from this template with the search phrase "HD wallpaper":
pexels.com-HD-wallpaper.epr
