Download from web online shop
de2apandi
Post by de2apandi »
Hi Maxim
How to download image from online shop, download only large image preview
from this site Here or maybe from here
can you make the project ?
thanks in advance
Re: Download from web online shop
This one must work with the default settings. Just exclude everything that doesn't lead to product pages and you'll be fine. Also note that they use PNG images for full-size preview. Not JPG as they usually do on show websites.
de2apandi
Post by de2apandi »
i'm use this setting
starting address
https://www.toydemon.com/meiki
Target
*.jp*
Site Exploration --> regular
* entire site
* Download files from external site
Filter
exclude
include
meiki
Limit
* image size W=800 H=800
how to exclude this
http://i.imgur.com/EiAndgi.png
http://i.imgur.com/bAGmO0y.png
and how to use Excluded Page Part ?
but i'm found image example from here not png maybe i'm wrong ?
https://www.toydemon.com/media/catalog/ ... s-main.jpg
Well, you excluded everything using
in the Excluded filters. If you want EPF to scan this URL:
then you have to add something to the Included URLs filter. For example:
media/catalog/product
de2apandi
Post by de2apandi »
yes image found but how to exclude annoying page sorting like https://www.toydemon.com/meiki--neutral ... estsellers
You say the original picture png but i'm not found that, the found jpg only, yes the resolution is big but watermarked maybe it protected or what ?
OK, turned out some of the full-size images are JPG, some are PNG. So, which part of the website do you want? Or you want entire website?
de2apandi
Post by de2apandi »
If can entire website :D
thanks before :)
Well, sometimes it's easier not to go the "exclude everything" path. You can try using the default settings, start the project and watch the download log... Then simply add filters to the "Excluded URLs" as you see the URLs that you don't need. That's how I created this project:
projects/ToyDemon.com.exe
de2apandi
Post by de2apandi »
OK thanks for File Project,
