Simple Machines forums
PP100
Post by PP100 »
Hi
Is there a suggested template for Simple Machines forum threads?
Let's say as an example I want to find all images in this thread
http://saradas.org/index.php?topic=305989.0
or multi paged thread here as example
http://saradas.org/index.php?topic=266081.0
then I hopefully only need to change the topic number (and/or possibly the external picture host) for other multi paged threads?
Re: Simple Machines forums
OK, try this one:
projects/saradas.org-266081.0.exe
You can use it as a template for this forum by simply changing the starting address and adding new image sources, if necessary.
PP100
Post by PP100 »
Thanks Maxim that works and I will hopefully be able to modify that later.
Appreciated.
