i cant download from this site
http://pics77.blogspot.com
example : http://pics77.blogspot.com/2011/07/chik ... tions.html
in my country this site is blocked by goverment with url : http://internet-positif.org/site.block? ... NvbQ%3D%3D
how i can download from this site
Thnks
help, how to download
Re: help, how to download
Do you have a direct connection to the Internet or you are connected through a proxy server?
direct connection,
but to open blocked web, i usually use web proxy
Oh, OK, then use a proxy to bypass blocks in the EPF settings. Then create a project with all default settings and check "Manul login" box. Should work. If it won't - let me know.
i use http://free-proxyserver.com/browse.php? ... Qc%3D&b=29
and manual login checked
but ist zero target file,
setting
tarting address: http://free-proxyserver.com/browse.php? ... Qc%3D&b=29
Target files: *.jp*
Site exploration -> Regular site: Follow all links
Filters -> Excluded URLs:
Filters -> Included URLs:
/show/.+?\.jpg$
i\d+\.imgchili\.net
Limits -> Image size: Min widht: 100px, Min height: 100px
setting
Target files: *.jp*
/show/.+?\.jpg$
i\d+\.imgchili\.net
No, no, no! The starting address should be the actual starting page of the site. And in the program settings you should enter one of the free open proxies to bypass blocks.
Does it make any sense to you?
doesn't work, in login manual allways stop on internet positif (blocked) and can't continue
i use a lot combination proxy IP address from internet, and always blocked. or in my browser must use proxy server to?
Yes, try to use the same proxy in browser and EPF.
it's work, but can you give me setting for filter : include and exclude for faster to find picture
i use setting
/show/.+?\.jpg$
i\d+\.imgchili\.net
but its take long time to find picture
if i use Filters -> Excluded URLs: .*, its no find picture
i use setting
/show/.+?\.jpg$
i\d+\.imgchili\.net
OK, here is a project for this website:
projects/pics77.blogspot.com.exe
If you're using .* in the "Excluded URLs" - this means "excluded EVERYTHING" except for the "Included URLs"... So you had to add some filters to let EPF crawl the pages on "pics77.blogspot.com" too. So I did use .* in the Excluded URLs and the Included URLs are:
^http://imgchili\.net/show/
^http://imgchili\.net/album/
i\d+\.imgchili\.net/.+?\.jpg$
pics77\.blogspot\.com/\d+[^\?]+\.html$
