limit picture for keywords
Hello. I want to purchase this awesome tool, but before I do it I want to confirm, can I limit the number of images downloaded per keyword? Actually I want download 20 images per keyword...
Re: limit picture for keywords
Yes, can set the maximum number of saved images per keyword. There are 2 ways to do it:
1. When you create a new search project click "Next" button several times to get to step 3 where you can select the engines you want and the picture limit.
Please note, that the limit of images is applied per search engine. So if you set the limit to 20 and select all 5 engines - you'll end up with 5 * 20 = 100 images. And if you want 20 images using 5 engines - set the limit to 4. Or select only Google and set the limit to 20.
2. In the search project properties this option can be found in the Limits -> Results number section.
