I am a newbie, so, sorry, if this is basic, but I can't get the EPF to download pics :(
I want to download a thread from the forum http://celebforum.to/
A starting address would be
http://celebforum.to/events-websites-an ... oy-12.html for example.
One example is a link to this page (a thumbnail is displayed):
http://img156.imagevenue.com/img.php?im ... _150lo.jpg
containing this pic:
http://img156.imagevenue.com/aAfkjfp01f ... _150lo.jpg <-- This is what I want :)
There are maybe other imagehosters in the thread, this is just an example...
Any Ideas of how the settings have to be set?
Thank you!
Newb question
Re: Newb question
One way of doing it is using "Follow all links" option in the [ Site Exploration -> Regular site ], excluding all addresses by adding
to the Filters -> Excluded URLs
and then including only those you need in the Filters -> Included URLs.
First of all - you'll need all thread pages. The thread ID as an included URL will do just fine:
2633-playboy
Then you need to include all possible image sources. For imagevanue the filter is:
img\d+\.imagevenue
Basically that's it.
Another good way which does not require any filters at all would be adding every thread page as a starting address (easily done in the built-in URL generator - "Generate..." buuton under the list of starting addresses), using "Follow all links" option in the [ Site Exploration -> Regular site] and limiting the exploration depth to 2.
2633-playboy
img\d+\.imagevenue
Re: Newb question
Thank you, I tried it and this:
Great tool, great answer!
did it :)!Another good way which does not require any filters at all would be adding every thread page as a starting address (easily done in the built-in URL generator - "Generate..." buuton under the list of starting addresses), using "Follow all links" option in the [ Site Exploration -> Regular site] and limiting the exploration depth to 2.
