jpg images for navigation
jobenaus
Post by jobenaus »
I would like to switch the navigation buttons from one template to another one so they are generated in the new template, but am unable to find where the buttons are located. I Can see them once they are generated, but not when trying ti edit the templates. Can you help?
thanks
John
Re: jpg images for navigation
Hello John,
All template files, including CSS, JavaScript and images are located in the "files" sub-folder of the template folder (all templates are actually folders). Extreme Thumbnail Generator stores all its files, including templates, inside the "Data folder". You can find the location of the "Data folder" in the Extreme Thumbnail Generator settings (menu command Tools->Settings...), on the "Advanced" tab.
So open this "Data folder" in Windows Explorer, get inside the "Templates" sub-folder, find your template and replace any images files you want.
jobenaus
Post by jobenaus »
Thanks....It was a hidden folder I was not finding.
Have you found it this time?
