Need help to download images from the below site , the URL as follows
http://www.desibees.com/thread-544.html
http://www.desibees.com/thread-1067.html
thanks in advance
How to download from the below site
Re: How to download from the below site
Hi. Here are the settings:
Starting address: http://www.desibees.com/thread-544.html
Target files:
*.jp*
Site exploration -> Regular site: Follow all links
Site exploration -> Custom parsers: Clear all parsers
Filters -> Excluded URLs:
Filters -> Included URLs:
thread-544-page-\d+\.html
picsbees\.com/view\.php?filename=
picsbees.com/img-
(?si)picsbees\.com/.+?\.((jpg)|(png)|(gif))
Limits -> File size: minimum file size 20 KB
Limits -> Image size: minimum image width and height: 300 px
That's it. Change the thread number from 544 to 1067 for your second address (make sure you change both starting address and one of the included filters.
Target files:
*.jp*
picsbees.com/img-
Thanks Maxim , I could able to download . But of some of them like below returns 0 files , anything we need add please
http://www.desibees.com/thread-3235.html
thanks in advance
thanks in advance
Well, viewing attachments on this forum requires to log in, so first of all you need to check the "Manual login (for websites with HTML forms)" box under the list of starting addresses. Then you need to add
attachment\.php?aid=\d+
to the "Included URLs". This must help. If it won't help - send me your username/password from this forum to support@exisoftware.com and I'll investigate further.
OK, turned out there was a problem with manual login (with cookie support actually), so you need to download the fixed version of the program:
Then add
attachment.php
to the "Target files" list and will work just fine!
Then add
attachment.php
It is working good Now after the Bug- fix install . thanks for your great support .
