I need to make a complex list of varying urls.
this is how the base url looks like:
www.site.com/12/02/XXXXXXXX/12/02/01/0123.mp4
I need the delimetres to follow this pattern -
www.site.com/12/[01-12]/XXXXXXXX/12/[01-12]/[01-31]/[00-23][00-59].mp4
This url represents a full year as you probably can figure out.
http://www.site.com/year/month/XXXXXXXX ... ursecs.mp4
Now when I try to use this as my base url in urlcreator I can't get the desired result:
www.site.com/12/[1]/XXXXXXXX/12/[2]/[3]/[4][5].mp4
I want [1]and [2] to follow each other without using the literate within and then [3][4][5] should literate within [1],[2] and themselves. However this won't work. I enclose a sample list:
It won't create the zero in front of the urls so results looks like this:
www.site.com/12/9/XXXXXXXX/12/9/2/1632.mp4
www.site.com/12/1/XXXXXXXX/12/1/1/07.mp4
When I actually wanted:
www.site.com/12/09/XXXXXXXX/12/09/02/1632.mp4
www.site.com/12/01/XXXXXXXX/12/01/01/0007.mp4
I do hope you understand what I am trying to do and that you are able to help out.
Thanks a lot in advance.
Help generate URLs
Re: Help generate URLs
You made 2 mistakes:
So the resulting settings are:
1. If you want the same digits in different parts of URL - use the same varying number.I want [1]and [2] to follow each other without using the literate
2. If you want leading zeroes - set "Digits" to "2" or "3" or anything else, depending on how many leading zeroes you need.It won't create the zero in front of the urls
