I would like to download large images from http://uk.tommy.com
normally the image is http://images.tommy.com/is/image/tommy/ ... _01?$zoom2$
without extention, has ?$zoom2$ means large image.
Thanks for your support
Can not download images
Re: Can not download images
OK, first of all please download and install the most recent version of the program:
It was just updated in order to work with sites like this. Then download and install the project I created for this website:
http://www.exisoftware.com/downloads/pi ... my.com.exe
Simply run the above file. It'll install a new project into the EPF project tree. Then run the project in the program.
Thanks so much, it works very well.
I have try with the website: http://www.nautica.com/
It looks like it uses Ajax to load Images or something that I can not use the software to download full size images.
Please take a look, if you have way to download from this site.
Have a great day,
Have a great day,
If by "full size images" you mean those images that you can see when you hover a mouse above the product image to see a zoomed-in version, then no, EPF can not download those. But it surely can download the *550x550.jpg product images using default project settings.
