Hello help
how to put in the program change the last letters with other letters
https://peopleimages.com/shoots#model:Vivi-SN
they are small pictures...I want to change the end for another....
it is possible to do it with the program, gracias...
Re: https://peopleimages.com
Yes, you can. You will need to add the following Custom Parser in the project properties:
Expression: "(http[^"]+-)box_175_175.jpg"
Result: [#1]zoom_90.jpg
And I think you should use the following mask in the Target Files:
to make sure only big files are saved.
thanks... another problem is that they are hosted on different links
https://cdn2.peopleimages.com/picture/201708/
https://cdn1.peopleimages.com/picture/201708/
https://cdn0.peopleimages.com/picture/201708/
where do I put it??
where do I put it??
You mean thumbnail and full-size images are located on different servers? Like thumbnail on cdn0 and full-size image on cdn2?
As for Target Files - open the project properties (menu item [ Project -> Project properties... ] ) select the "Target files" section and replace
with
with
on the website they are small but if with the program you can change before downloading change this fit_400_400.jpg for this zoom_90.jpg
Expression: "(http[^"]+-)fit_400_400.jpg"
