Why is it that the link back from some galleries is greyed out, mixed thumbnails for example?
I link to these galleries from my website so must have a way to get back
Any help gratefully received.
thanks Reg
link from gallery
Re: link from gallery
The "link back from the gallery" is greyed out when the appropriate special tag is absent in the template. But you can easily add it yourself. Simply select your template and click the Edit template.... In the built-in template editor select the Thumbnails pages section and add the following special tag: [#thumbspage.link_back#] where you want the link back to appear on the resulting pages. And if you want a link back from image pages also, then select the Image pages section and add the following special tag [#imagepage.link_back#] to the HTML text of the image pages template.
