Feature Request: Local, More Portable Settings
Shadeclan
Post by Shadeclan »
Could you please alter ESS so that if it finds an ESS.INI file in the local directory (not the Windows directory where the screensaver exe is but in the install directory), it will save all settings there? If the INI file exists, would you please cause Shown.dat to be created in the same directory or have a setting in the INI file which specifies where Shown.dat is located? Thanks - that would be a lot of help to me.
Re: Feature Request: Local, More Portable Settings
Yeah, OK. This feature is already in the to-do list. Can you tell me why are you requesting this feature? You deleted the shown.dat file?
