Performance of Endless Slideshow screensaver slow
ruudboek
Post by ruudboek » 21 Sep 2012, 20:12
I noticed that quite some transitions seem to stutter a bit. They are not so fluent or smooth.
Also the framerate of the crossfade and the fade-in/fade-out transitions seem a bit too slow.
I think this is rather strange because if am using a fairly reasonable computer (amd A6-3620).
Do you perhaps have any suggestions to make the transitions smoother?
Re: Performance of Endless Slideshow screensaver slow
Post by Maxim » 22 Sep 2012, 11:18
Yes, we're aware of this problem and we'll try to fix it.
ruudboek
Post by ruudboek » 22 Sep 2012, 13:39
Ah great that i am not the only one who noticed this ;)
Will you be able to fix this in the current 1.x version, or will that be in version 2.0?
I really like this screensaver, do you have any idea when a fixed version could be available?
Post by Maxim » 23 Sep 2012, 11:03
Most likely in 2.0. As for "when" - can't tell you right now.
ruudboek
Post by ruudboek » 23 Sep 2012, 14:50
Ok, Thanks Maxim. By the way, were there any older versions that did not have this problem?
Post by Maxim » 25 Sep 2012, 16:57
Nope. It worked like this from the very beginning...
