Dear Maxim,
I am trying to update my archive which i obtained from Flickr but I need to login to Flickr to see all the photo stream. If I click to the "update" button on EPF, manual login screen doesn't appear.If I click "restart" button, manual login screen is show up and able to successfully login.
In case, I have to restart and download all the 5000+ photos every time for a few new photos.
Is there any solution to this problem?
Thanks for your help,
korgunal
Problem with Flickr! Update without login
Re: Problem with Flickr! Update without login
Yes, I'm aware of this problem and I'll try to resolve it in the nearest release.
OK, I think the problem is fixed. Please download and install the new version of Extreme Picture Finder.
