just moved from JoJoSaver to ESS and I like it.
However, there is an issue displaying NEF (Nikon RAW) files on my machine. They show up in wrong colors.
Actually, this would be not an issue since I have those pics also as JPGs in the same folders.
Therefore it would be great if I could tell ESS to ignore certain file types.
Regards
ABi
Control file types
Re: Control file types
OK, we'll do it. Thanks for the suggestion.
Can we also filter out pictures smaller than X by Y pixels please?
OK, adding it to the to-do list.
Hi, do you already have a schedule for the next release?
No, currently there is no schedule for the next Endless Slideshow Screensaver release. Sorry. We're focusing on other projects.
Im needing it to exclude raw versions (NEF, CR2) as these render awfully, and just use the Jpegs. So am keen for an update that is promised above, that can exlude / select file types . Can you update us on when this feature is likely to be added. It would make a good product great
No estimation right now, but most likely - this month.
I also have this problem with Nikon Raw files is it fixed yet? I could not find anything in the options......????
This issue isn't resolved yet. Sorry.
