EUG - Out of memory
djmakinera
EUG - Out of memory
Post by djmakinera »
At generating links I receive such an announcement:
How to solve this problem?
Re: EUG - Out of memory
It looks like you're trying to generate a huge URL list (hundreds of millions of URLs). Please try to keep your projects smaller. Up to 10 million addresses.
djmakinera
I would like something like that as in the picture shown to generate. Is the RAM 2 GB too little? besides how many will be from it of links? And such a how much list would I have to after the piece create?
Correction: in the second row for column should be 10 instead of 100
OK, first of all - the "Out of memory" problem fixed and the new version is available for immediate download here:
http://www.exisoftware.com/url_generato ... _setup.exe
Now about your project. The settings you provided would generate 561,330,008,019,000 URLs. This is too much for the current version of the program. Maximum number of URLs it can generate in one project is 2,147,483,647.
Also I doubt any directory would easily hold 70000000 images - and this is exactly what you were trying to generate (varying number #4). So please check out those settings and reduce the numbers.
ricaluanna
Post by ricaluanna »
I can't see the image.
It must have been deleted by the original poster djmakinera. This image wasn't stored on our server.
utomo
Post by utomo »
yes, i think 70000000 images is too much
99.99999999% people will not use it
