Kemono.su scanning files from url
Is there a quick way to scan all the already downloaded files from a project? When i update a project, it's scanning the while URL again, and some take a while.
Re: Kemono.su scanning files from url
Right now, when you use the [ Update ] feature, the software re-downloads every page looking for new files. Can you suggest any other way?
I see. I thought maybe the program scans through the project and only download new files. Not that of a technical person so i dont know if that's even possible. I got this project with like 50k images from a single user. And if i have to redownload eveything just to update, tha's not worth it.
The idea behing the [ Update ] function is to make the software re-download only pages, not the actual Target Files. And if new files were found on those re-downloaded pages - new files are downloaded. Existing files shouldn't be re-downloaded. If they are - you can set the [ Do not download and save file if file size is the same ] option in the [ Save - Conflicts ] section of the project properties.
Understood. Thank you
