https://archive.org/ aka Internet Archive
user1
Post by user1 »
Hi, could someone make a template for the Internet Archive so one can download specifically ONLY the rar or zip content files from multiple tabs at once?
Here's an example, at the small button where it says 24 Files or the button with 15 Files:
https://archive.org/details/halo-combat ... om-edition
Thank you.
Re: https://archive.org/ aka Internet Archive
What "multiple tabs" are we talking about? I opened your address - there were no tabs.
user1
Post by user1 »
Here's the another tab
https://archive.org/details/3-d-pinball-for-windows.-7z
The button where it says 9 files, If it's possible to have the 2 compressed files at the same time?, One being halo and the other being 3d pinball?
The compressed file of 3d pinball has 9 Files
This is not a tab. It's a completely different page. I do not see any tabs anywhere on this page :( Plus, I do not see any connection between the two page addresses you provided. They are not linked together in any way.
If you want a project that downloads one file from one address (or a list of addresses), then here it is:
archive.org-zip-downloader.epr
Right-click the above address and select [ Save target as... ]. After that, double-click the downloaded project file to add the project to Extreme Picture Finder. Then, open the project properties, paste your URL list into the [ Starting addresses ] field, save the project and start it.
user1
Post by user1 »
I tried using the template but it keeps re downloading the compressed file over and over again and it's impossible to grab the file from windows explorer.
