Kiutaku.com
Breadkim
Kiutaku.com
Post by Breadkim »
Sir, Please create a template for this website
Kiutaku.com
And I'd appreciate it if you could add it to the template download page
Please
Re: Kiutaku.com
Please try this template and let me know if it worked for you:
kiutaku.com downloader
Breadkim
Re: Kiutaku.com
Post by Breadkim »
Thank you so much for your quick response. If possible, can you make a template for 4khd.com ?
I purchased EPF and am using it well. Thank you
Breadkim
Re: Kiutaku.com
Post by Breadkim »
I used the kiutaku.com downloader you gave me and it works so well
Could you please share by email how to make the template?
I want to learn and use it
Re: Kiutaku.com
You didn't really need any specific template for this website. You could have created a project with the default settings or used the generic template called "Download all images from the entire website" to do the job. You can try it yourself with 4khd.com.
And here is some basic information showing how to configure Extreme Picture Finder: Limiting Extreme Picture Finder exploration
Breadkim
Re: Kiutaku.com
Post by Breadkim »
Thanks you sir
